clutch springs
Old Aug 12, 1999 | 05:57 PM
bodineus's Avatar
Wondering what the best springs and weights would be for better off the line performance, and would it affect my top end, yes I will be putting a pipe and silincer on.
thanks
Old Aug 12, 1999 | 06:11 PM
A400L's Avatar
Uhhh...what machine do you own and what mods are on it now?
Jerry Goodman '99 400L, '98 TBlazer
Old Aug 13, 1999 | 11:02 AM
bodineus's Avatar
Oh yea.. I guess that would of helped very sorry. The bike is a 98 400 sport and a 2000 trilblazer, they both have airbox mods now, the sport has a pipe and silencer waiting to put on I just thought I would do it all at once.
Thanks
Old Aug 13, 1999 | 11:36 AM
A400L's Avatar
Who's pipe do you have? They should be able to suggest a spring to get you started. From there its mostly rider preference and how you like your engagement.
When I put my RCR midrange pipe on I used a modified plain spirng. When I moved up to the Hi-rev pipe I used an HPD Orange, but have since changed to a HPD Red/Yellow. I also have an AAEN roller kit w/HPD Lavender secondary and 54GM. weights. Once you get this far you really need a tachometer to dial a clutch in.
My engagement is at 4000RPM's. So when I get on the gas hard, look out! Its probably too violent for most people, I'm even thinking of tuning it down just a bit. The motor revs out at 7000RPM's (stock, or slightly modified is between 5800-6200)
What springs/weights do for you is change the engagement and back shift of the tranny. There is no one set up that works for everyone. I would suggest buying AAEN's clutch tuning handbook ($20) which will explain everything to you better than I could in a simple post.
I put the plain that I had originally had on my Sport on my TBlazer. Its bone stock, but the spring just raised the engagement RPM's a tad.
With some springs costing $20 it can get a bit expensive trying to find one that you like. Anyway, to answer your question start with a HPD Plain or maybe Brown (slightly higher engagement that Plain).
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
