what wrong now!
Old Jun 15, 2013 | 04:51 PM
"IF" it's an internal carb problem,don't expect Sea-foam,Stabil,etc to do that good of a job,may not always work.. The best way to clean a carb is the old fashioned way,physically clean it up.Use Sea-foam,Stabil as a preservative. This carb is similar to yours.The BST-40 Bible - ADVrider Plus if you don't have a service manual,get one! Will pay for itself quick if you plan on doing your own maintenance and repairs. Plus this free 2009 500 pdf service manual has the same carb and many of the same parts as yours to use as a reference. PartShark.com - Motorcycle Parts, ATV Parts, UTV Parts, PWC Parts, Powersports Apparel, Motorcycle Accessories for OEM and Aftermarket.
Old Jun 17, 2013 | 12:31 PM
mad-atver's Avatar
today i took it for a short ride and was doing about 50mph then it bogged and stalled. i drove it home and it was idling good then it suddenly stalled again and would only start and run with the choke on, whats this sound like?
Old Jun 17, 2013 | 01:58 PM
mad-atver's Avatar
it won't stay running for 2 secpnds now where is the fuel filter located?
Old Jun 17, 2013 | 02:25 PM
bjones12's Avatar
Sounds like... you probably should listen to OPT. Take the carb off, and clean it. With the ethanol infused fuel that has been forced on us, we have to constantly clean the carbs. Once clean you should try to find some filling stations that sell ethanol-free gasoline. The ethanol gas creates havoc on fuel lines, fuel filters, and carbs.
Old Jun 17, 2013 | 02:30 PM
  #15
mad-atver's Avatar
ok i pulled the 3 lines off my fuel pump and the top line pissed gas out all over, the middle one just dripped and the bottom of the fuel pump had no fuel coming out, is my fuel pump done?
Old Jun 17, 2013 | 06:12 PM
  #16
Axton's Avatar
Check your air filter connection to the engine. I had the same problem, it turned out my air filter came out from the engine. I dunno why, but it took away power.
EDIT:
Oh.. It's not feeding fuel. Clean your carb as others stated.
Old Jun 17, 2013 | 06:14 PM
  #17
Axton's Avatar
Also, i hope you turned off the gas flow. There's a switch on the left side that lets you control gas flow.
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
