Sportsman will not start, please help!
#21
#22
#24
there should be 2 wires into the yellow starter switch ( handlebar )
1 power feed wire in , 1 red/white power feed wire out to starter solenoid
check the other colour wire ( not the red/white one ) for input voltage
if the that wire does not show voltage present , then that is the wire you need to trace back to the fuse panel
#25
Hey guys, I am happy to tell you that I found the problem. I tore all the plastics off again to follow the wires from the solenoid into the main harness. I pulled all the tubing off and the electrical tape on the harness and made my way to the pod. Well stupid me, I should have started at the pod first because I found three broken wire about six inches from the ignition swich. I mended the wires with waterproof splices, and she started right up. I re-wrapped al the wire and put it back together and went on a ride. Thank you everyone for your help!
whitty
67
02-24-2021 02:52 PM
