1993 polaris 250 2 cycle 4x4 starter
ok i have this 1993 polaris 250 2 cycle 4x4 anyway with you alls help i got the thing running the starter worked for a wile now all i get is a click how hard is it to pull ? it dose have a new battery and will not work by jumping the starter thanks
You can either tip it on it's end and remove the bash plate and fight the starter bracket bolts OR pull the clutches,backing plate,recoil housing for the 2 inside starter bolts,but the bracket is right there and easy to pull the starter and bendix out as an assembly.Only special tool you'd need a drive clutch puller.http://www.ebay.com/itm/Polaris-ATV-Primary-Drive-Clutch-Puller-Tool-1985-UP-/200998288394?pt=Motorcycles_Parts_Accessories&hash=item2ecc6e7c0a&vxp=mtrPlus here's a cheap place a on starters and bendix(gear shafts). I'd replace it also as you'd either have to pull the clutches again or the flywheel just to replace the bendix if it goes out. DB Electrical - 250
