Why did they give up on two-strokes?
Old 01-28-2014, 07:35 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Originally Posted by TLC
An other issue with a 4 stroke chainsaw besides power to weight is can a 4 stroke be run at any position or angle like upsidedown?
My 4 stroke Honda outboard motor can only be transported in two positions or oil runs from the crank into the valves and its has to sit a long while to start up again.
my 4 stroke weed wacker has a diaphram carb- makes no difference how I turn it.
  #42
Old 01-28-2014, 09:14 AM
TLC's Avatar
TLC
TLC is offline
A chainsaw needs a lot more power then a weed wacker to do its job.
I have a newer 2hp Honda outboard 4 stroke and to just make that little power it needs 57cc of displacement.
A 2stroke 2hp is 40cc in comparison .
By the time a 4stoke chainsaw has the power to get the job done you could end up with a 200cc 50lb monster in your hands.
  #43
Old 01-28-2014, 11:18 AM
keithert's Avatar
When looking for my first couple ATVs I did not want a two stroke. Then this year a Polaris Trailboss 250 fell into my lap. It is now my favorite ATV. The 2 stroke power is much better than what my Honda Fourtrax 300 has. I love how this machine can break the rear end out easily in a turn. I'd like a Polaris 400 4x4 model.
  #44
Old 01-28-2014, 11:23 AM
keithert's Avatar
Originally Posted by Scootergptx
Uncork an old 250 trail blazer and you'd be surprised how much quicker it could be than the 400ex.
How should the uncorking be done?
  #45
Old 01-28-2014, 11:30 AM
scootergptx's Avatar
Supersock
Hired Gun!
Lots of stuff can be done to open them up. Externally, different pipe, better flowing air filter and a simple spring change on the clutch.
Check with Rick Ritter and he can get you all the stuff you'll need. Depending on the depth of your pockets, you can build a pretty quick machine.
Just wish it had a better suspension on the front.
Sassinm1
09-30-2015 04:23 AM
09-30-2015 01:37 AM
woodthings
09-25-2015 05:58 PM
jankerstien
09-21-2015 03:09 AM
Minimod
09-10-2015 08:03 AM
Quick Reply: Why did they give up on two-strokes?
