2012 sportsman 500 stalls
My friend in new hamp polaris stalls when he turns to the right only and when it at idle only. It doesnt stall when rpms are up and it doesnt stall when you turn to the left at idle. Im not up there so i cant look at it. Does anyone have any ideas. Thnx
I was told when the cluster odom/tac is not screwed down and seated properly it wont run either. Like i said im not with the atv so just getting info over the phone. Sounds to me its a loose wire or bad connection somewhere. Thnx again
Problem appears to be in the gray connector. What would cause the stalling in that connector??
First thing I'd have him check the throttle cable for too much slack. If the internal etc contacts touch it will die,but will run ok when throttle is applied.Must not have more than 1/8" slack at the throttle lever.After the throttle adjustment is made he may have to adjust the idle on the carb also to maintain a good idle.Sounds like he's been messing with the cable or it's just stretched over time.
