U-joint problems
Old Apr 1, 2001 | 01:04 PM
polarisz71's Avatar
Last weekend i went riding and I got no more than 300ft. out of my lane before the u-joint popped off the drive shaft to the wheel. Now it'll be at least a couple weeks before the dealer will be able to get to fix it. So, to save me time and money how hard is it to fix the drive shaft and/or the u-joint?
Old Apr 1, 2001 | 02:12 PM
Dazed's Avatar
It is rather easy to do, napa has those joints in stock so check with them ,Or do a search for the ujoint # on the forum you will find them.
Old Apr 2, 2001 | 12:51 AM
polarisz71's Avatar
Good. I'm still going to have the dealer look at it to see if I hurt anything else. I might have hurt the driveshaft or the housing because I spun it around a couple times trying to get the thing to where my truck could get to it.
Old Apr 2, 2001 | 10:51 AM
gregsims's Avatar
The u-joints for the rear axel on a 98 SP500 are Neapco part#1-1275 Pep Boys $15 Polaris $55
Neapco part#1-1875
This is the same part your bike came with. neapco makes this u-joint for Polaris. If you have an ounce of commen sense, you should be able to handle thgis without a trip to the dealer. Usually when the u-jount gets so bad that it comes out, the yoke is going to be damaged, which means you will have to buy a new one... the proble is that both yokes are usually bent a little which means you need both peices. They are $60 each. You can buy the whole axel for $180, and that is what i would do if the yokes are damaged. If the bearing carrier is damaged, that will be another $60 and if the lower a-arm is damaged, that is another $60. Also, if the bearing carrier is damaged, good luck getting the bearing out. I had to go back into the shop at the Polaris place in Marshall texas and do it myself because the dealers mech could not get it out.
Greg
Old Apr 2, 2001 | 08:05 PM
Sparke's Avatar
It is really easy, dont spend the money to have the dealer do it. Yes you can buy the u-joint at napa, the part number is 507.
The hardest part is pounding the caps out of the shaft. Make sure you pop the clip before you start, not that I havn't.
It is a pretty greasy ordeal though, so be ready to get dirty.
Sparke 98 SP 500
Old Apr 3, 2001 | 01:43 AM
polarisz71's Avatar
Thanx for the info. I'm still going to have the dealer make a list of what parts to get and I'll do the job myself. I'm also going to go through the whole quad again and make sure all the zerks take grease, and replace them if they don't.
Old Apr 3, 2001 | 10:37 PM
polarisz71's Avatar
Found out how much I have to do. I have to replace both u-joints, the right drive shaft, and I twisted the splines in the tranny. All of this will be approximately $500.
polarisz71's Avatar
Old Apr 7, 2001 | 04:13 PM
Binky's Avatar
I sent you an e-mail describing the fun I had doing the same job on mine I hope it helps.
Old Apr 7, 2001 | 07:15 PM
mudmachine's Avatar
See, I knew there was something wrong with that Dealership in Marshall.... Gregs been back there!!!!!... haha... Just kiddin greg..
Thats not much of a shop or dealership. That guy sold a bike to a lady friend of mine and 3 months later it broke the rear axle, He tried to stick it to her by saying that it wasn't under warranty. (2000 Expedition 425, Stock bike, no mods, girl driver)He told her to write him a check for the parts and labor bill, then he'd do HER a favor and TRY to get Polaris to cover some of it... IF he could pull it off, he'd mail her check back to her... LIKE HE WAS DOING HER A FAVOR!!!..
I could post how I REALLY feel about that dealership, but it would probably get deleted and I would get banned...
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
