fan problem on 425 expedition
Old Sep 19, 1999 | 10:45 PM
toolman40269's Avatar
i have a 2000 polaris 425 expedition my fan quit working and i can't find the problem. i've already jumped the fan to the battery and the fan motor works. any ideas?
Old Sep 20, 1999 | 12:00 AM
Odin's Avatar
The fan is controlled by a thermostatic switch which screws into the back of the top of your radiator. Some of these switches do not turn on until the engine appears to be running rather warm. (been there, replaced mine.)
You might also trace down the wiring to the fan and make sure that you have a good connection at the electrical junction box. If the connection is good and the feed wire is not broken and there is no blown fuse, then the thermostat is defective. Good luck.
Old Sep 26, 1999 | 10:57 AM
xpoltech's Avatar
Have you checked to see if the sencer kick's on at the correct temp?
Old Sep 26, 1999 | 09:39 PM
thanks for the help. it was a bad thermostat after all.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
