grease zerk
Pressed in on this one. Just go to an auto store and get a 1/4-28 pitch threaded one and tap the rear housing then you won't have any more problems on one pulling out,OR you can just try another push in.Most auto/hardware stores have both in 1/4".http://www.ebay.com/itm/Polaris-Lube-Fitting-With-Ball-7080306-ALL-models-in-description-SOLD-INDIVID-/201091362928?pt=Motors_ATV_Parts_Accessories&hash=item2ed1fab070&vxp=mtr
Yes as it shrinks the metal fitting a minute amount. Also you can heat the housing to where it expands a little making it easier to install. Then let it cool off. Same principle as installing bearings in an engine case,put the bearings in the freezer,heat the case and a lot of times bearings just drop in. Once cooled you have to knock them out to remove them.
