will this clutch kit fit into my scrambler
07 Polaris Sportsman 800 X2 Epi Clutch Kit for 27" 28" Tire Size | eBay
scrambler is a 98
if not, what is the difference?
if so, is this kit any good?
its about 5 miles from me is why i need to know, dont want to wait for shipping if i dont have to
scrambler is a 98
scrambler is a 98
scrambler is a 98
Your whole clutch system is different than the 800. You don't have the ebs system with the one way bearing in the front clutch and rear clutch is different also.This one will work,but shows two different style stationary ramps(helix) in the description. Your helix is on the right.Epi Sport Utility Clutch Kit 27 28" Tires WE425005 | eBay
scrammy is stock, just trying to get better low end torque and response..the epi site says that kit was non ebs i think thats why i thought it may work..was under the impression all these clutches were pretty much the same exept the ebs cluthches...
It is odd that it states it will fit your model but as OPT indicated, fitment is often incorrectly represented. For a stock engine set up, you may only want a primary weight and spring change. Try Aaen, Team Roller, HPD, and EPI website. Might even have a Vender here that supports this site that you could have a look at.
