LED light bar and wiring?
Old Sep 5, 2016 | 04:51 PM
WilliamBos's Avatar
Default LED light bar and wiring?
Added a 6" led light bar wired in to my high beams. Draws less than the lows.
I'd like to mount one on the rear for backing up. Can I wire in to reverse over ride, so I just press if needed? It would be a great day time back up light too.
Attached Thumbnails LED light bar and wiring?-20160903_143712.jpg   LED light bar and wiring?-20160903_202630_richtone-hdr-.jpg
Old Sep 6, 2016 | 09:39 PM
SOLOLUCKY's Avatar
my buddy did it on his yamaha...he wired a relay into the wire that lites up the "R" on the dashboard so when he hits reverse it powers the relay, thus sending power to the lite....not exactly how you were planning but how he did it and a viable option for you.
Old Sep 13, 2016 | 01:20 AM
switzomatic's Avatar
There's a sensor by the shift linkage that sends the info to the dash. If you have a manual, the schematic should show which wire is for the reverse indicator. Pretty sure that should do the trick. OPT would know best. Was easier on the older (mid 2000's) Polaris models which were factory wired for the revers light kit. Had a plug right in the headlight pod.
Old Sep 13, 2016 | 05:34 PM
WilliamBos's Avatar
Attached are schematic and a pic. The yellow is the reverse wire, so I can tie in to that. Where can I ground it?
Attached Thumbnails LED light bar and wiring?-20160913_180958.jpg   LED light bar and wiring?-20160913_181630.jpg
Old Sep 14, 2016 | 04:25 AM
I would think you can ground it on the frame.
Old Sep 14, 2016 | 07:35 AM
WilliamBos's Avatar
Excellent. Thank you.
500sportsman2002
Feb 25, 2019 03:47 PM
scottaruth
May 1, 2016 01:00 AM
Zephead98
Apr 10, 2016 11:08 AM
chuck1177
Mar 6, 2016 02:23 AM
jdunbar
Feb 18, 2016 07:51 AM
