Scrambler 90
#31
#34
IF this is the good engine(I'm still confused) replace the crank seals while you have it torn down.If it's the bad one,never mind Remove the drive clutch and the remove the gear plate. That is if this is the one that has the bad gears,good engine or if I have it reversed.Either way both gear cases have to come apart.Now I'm babbling....
#38
#40
