Found my oil leak - cylinder gasket
#121
YOU HAVE ONE WORN OUT DRIVE CLUTCH.... If the spider towers where the guide buttons ride look like what I think they do, deeply grooved,probably wouldn't help to try to rebuild this clutch. That's no big deal as cheap clutches from Niche,etc are out there now. Pull the clutch cover,remove the clutch and then you can check for any abnormal engine noises.. Yes replace any washer that's seeping along with replacing the thermostat since you basically have a brand new engine. Plus Niche and Ace clutches are as low as $116 complete.ALL non ebs drive clutches will interchange. Just use your spring and counter weights.https://www.ebay.com/sch/i.html?_fro...lutch&_sacat=0
#124
Originally Posted by I.b01
In case you haven't already replaced any yet, don't forget that the banjo washers are not steel, but aluminum or copper crush washers.
#126
Had to replace a couple of the banjo washers after all. They were cheap and in stock. I have a clutch puller ordered, it's now cheaper than homemade version you recommended awhile back. Also ordered new after market thermostat.
Took a small test drive and everything seems good.
Clutch will be next project, the 1999 after market one in Canadian dollars is not cheap. I'd like to look at the old one first to see what is worn out.
Not sure if it's still a Polaris - more of an aftermarket version now...
#127
Look at the towers on the spider where the guide bushings ride. Bushings are probably worn anyway,but if the towers are deeply grooved,rebuilding clutches like this usually doesn't help. They will still clatter and knock. I've had them come in sounding worse than yours,more like a diesel clatter.All I did was pop em off and throw on a new clutch. Don't over look the rear clutch ramp buttons. I'd order 3 new ones and have the driven clutch in good shape also. If the belt needs replacing use the oem 3211077 Polaris belt. Newer style ramp buttons or the older style brown ramp buttons. Either style will work. Just find the cheapest ones. https://www.ebay.com/itm/3-OEM-2000-...1aMyma&vxp=mtr https://www.ebay.com/itm/Polaris-Xpl....c100005.m1851 Parts Ace clutches are the cheapest I've found, may be higher up north, but still a lot cheaper than a 500 buck oem clutch.
#128
#129
Clutch is definitely trash. Remove it like I mentioned earlier and you can check for any other noises that may or may not be engine related. Plus the squealing coming down from speed could be from the belt or even the drive or driven clutches themselves. These engines are pretty quiet for the most part when you remove old worn out clattering clutches out of the way. That's why I mentioned replacing the ramp buttons also. If worn down, the helix can grind against the clutch and make a screeching metallic noise. If the noises are gone with the clutches removed,you've found the problem. At least a good start.
#130
