Found my oil leak - cylinder gasket
Old Dec 3, 2017 | 06:04 PM
  #21
Originally Posted by Simon Miller
Entire head was removed with no problem. But cylinder won’t come off. I’m worried I now have to pull the entire engine out. Don’t have a flywheel puller - way too much $$$ for a one time job. Was trying to remove cylinder with engine in place. So hard to access all the places where I can hammer.
Did you download the manual I listed? If you didn't sounds like you didn't remove the 4 bolts INSIDE the cylinder water jacket along with the two 6mm bolts. Manual shows disassembly step by step with the bolts pictured. Good way to crack a cylinder if you didn't.
4. Remove the two 6 mm cylinder base bolts.
5. Loosen each of the four large cylinder base bolts 1/4 turn
at a time in a criss-cross pattern until loose and remove
bolts.
NOTE: The bolts are inside the water jacket.
Old Dec 3, 2017 | 06:10 PM
  #22
Simon Miller's Avatar
Oh crap. Yes - I have the manual, but I missed the 4 bolts in the water jacket. For crying out loud - I’m cursing like a sailer. OPT - u saved the day again!
... back to work...
Old Dec 3, 2017 | 06:18 PM
  #23
If you cracked the cylinder I didn't exactly save the day for you.. Oh well you said you were planning on replacing it as a kit..
Old Dec 3, 2017 | 06:25 PM
  #24
I don’t have the 12 point socket to remove it tonight, will buy one tomorrow. But I’m going to bed knowing how to solve the problem. Replacing the cylinder is a small price to pay compared to pulling the entire engine to then realize my mistake.
The kit I’m looking at has a new tensioner plus the cylinder. The chain slipped again - so I’m assuming it’s the tensioner. Timing was not off, but chain was lined up the way I had set it before.
Old Dec 3, 2017 | 06:33 PM
  #25
If you're going to all that trouble order a new chain. Especially if the chain feels the least bit loose or the tensioner is all the way out.
Old Dec 3, 2017 | 10:34 PM
  #26
user493's Avatar
Moto Psycho
That's what I was thinking too. Chains stretch over time and it would be easier to change it now than to go back and do it later.
Old Dec 3, 2017 | 10:37 PM
  #27
Will do. Thanks again.
Old Dec 4, 2017 | 07:30 AM
  #28
Can you remove the chain without having to pull the flywheel?
Old Dec 4, 2017 | 08:39 AM
  #29
Nope gotta pull the flywheel. Not that big of a deal as you can rent a harmonic balancer puller at most auto parts houses for a small refundable deposit rather than buying one if you wish. Mark the stator plate and case with a pin punch even if you may have marks on it anyway. This makes sure you have stator timing correct when you reinstall it. Make sure the lower crank sprocket is tight. Left hand threads on the slotted nut holding it in place on the woodruff key so be careful.Just a simple tap with a punch and hammer to make sure. Look at the manual carefully as it shows how to time the chain up correctly with the plated links. Look at these pics that a member took when he timed his up. One plated link on the lower sprocket mark,two plated links on the two dots on the cam sprocket.https://atvconnection.com/forums/pol...ml#post3305250
Old Dec 4, 2017 | 11:57 AM
  #30
I found a video on using the balance harmonica - is there a better way to hold the flywheel in place than a strap?
