Found my oil leak - cylinder gasket
Old Dec 4, 2017 | 04:27 PM
  #31
Puller is ok but you need an air impact or you won't get it off. Look at this video on a 700 engine in a dune buggy. Similar to the 500 and shows how snug flywheels are on these tapered shafts.Need that air impact. Look starting at the 2:45 mark.
Old Dec 4, 2017 | 04:53 PM
  #32
Simon Miller's Avatar
That’s what I thought. Need another tool. Will have a good collection when I’m done.
Old Dec 4, 2017 | 08:37 PM
  #33
Yup - torque wrench is the only way to get the flywheel nut off. Popped right off.
Back in business - just need to wait for the top end kit to arrive, along with some other parts like the chain. Need to finish the engine disassembly, and can then start to put it all back together again.
Hoping for no more surprises....
Old Dec 5, 2017 | 08:11 AM
  #34
Always expect the unexpected. Read the manual slowly and follow each step.
Old Dec 5, 2017 | 10:56 AM
  #35
Next challenge - flywheel won't come off. Broke the bolts on the tool. The rental place won't be happy. Now what?Found my oil leak - cylinder gasket-photo408.jpg
Old Dec 5, 2017 | 11:51 AM
  #36
For one thing thread the bolts a little deeper into the flywheel without touching the stator. You can get a grade 8 8mm flange bolt at most hardware stores to replace the broken one.
Old Dec 5, 2017 | 01:19 PM
  #37
I bought new high grade bolts, the one with the tool were low grade. Still not coming off - I'm worried about apply too much force and breaking something. Is a torque wrench ok to use?
Old Dec 5, 2017 | 01:37 PM
  #38
While you have pressure on the flywheel,apply a little heat from a propane torch around the crank shaft area then use an air impact like shown in the video I posted. If you have enough pressure on the puller sometimes heat alone will cause a flywheel to pop right off. Plus looks like you have the flat piece on the puller. Remove it to where you have the tapered end of the puller bolt against the shaft.
Old Dec 5, 2017 | 01:40 PM
  #39
Sorry - I meant impact wrench, not torque wrench. Will try this soon.
Old Dec 5, 2017 | 02:40 PM
  #40
user493's Avatar
Moto Psycho
I assumed you meant impact wrench on post #33 too. You could wreck a torque wrench using it to unscrew nuts or bolts.
