96 polaris 400 xpress 2 stroke
Old Feb 18, 2018 | 02:28 PM
BoneCrushingfun's Avatar
Default 96 polaris 400 xpress 2 stroke
I have an issue with my idle I recently replaced my piston and gaskets and seals now I have a very high idle before I diagnosed the original problem being a broken piston I was adjusting the idle screw to try and fix the rough idle then I found out my piston was broke so I replaced that now I have a very high idle even when I turn my idle screw in all the way even in full choke I have tried a lot of the tips it has a muculli carb on it my air/fuel screw is at 1 1/2 turns out I need help
Old Feb 18, 2018 | 03:19 PM
Guess you mean Mikuni carb.. Did you have the cylinder bored to the next over size piston and rings? Replace the crank seals? Made sure you flushed the crank case for any metal shavings? Have a little slack at the thumb lever,no more than 1/8" free play to rule out a tight throttle cable? Several questions,but any of these can cause problems as you don't give much info.
Old Feb 19, 2018 | 08:12 PM
yes I did all that throttle is at 1/8 slack I think I might have turned up the idle and yes it is a mikuli carb I'm a little unsure as to which way to turn the idle screw clock wise or counter clock wise rather in or out
Old Feb 20, 2018 | 01:59 AM
Yes sorry mikuni carb not mikuli carb
Old Feb 20, 2018 | 07:12 AM
Turning the idle screw inward raises the slide which increases the rpm. Tuning it out lowers the slide,decreasing idle speed.
Old Feb 20, 2018 | 06:05 PM
thank you will have to try that on my next day off will let you know if any more problems a rise
Polarisracr2010
Sep 6, 2008 11:58 PM
Polarisracr2010
Apr 6, 2008 08:38 PM
hybridtheoryd16
Aug 7, 2006 11:25 PM
cmatthews24
Utility ATVs
Mar 3, 2005 02:21 PM
