gps mounts
Old Apr 21, 2001 | 11:33 PM
KISSSOFDEATH's Avatar
Quadnut, have you had any problems with your RAM mount coming loose?
Old Apr 22, 2001 | 08:57 PM
quadnut's Avatar
I have not had ANY problems with the RAM Mount. If you are concerned about vibration, I would not worry to much, The Ram Mount uses rubber on the Mounts so there is little risk of loosening. The mount parts can be purchased seperatly, so if you wanted to use your GPS on several different cars, bikes, quads, or boats, all you need to do is buy the mount BASE for each of your applications (they are not that expensive).
Another note... The RAM mount has been tested to something like 5g's... it won't fall off, or break when put under extreme conditions.
Just my opinion. Use what works best for you!
Old Apr 22, 2001 | 10:44 PM
aheadofu's Avatar
I also vecro mine to the gas tank. It's a Lawrance Global 100. This has worked well for me.
Old Apr 22, 2001 | 11:00 PM
MNT's Avatar
MNT
http://www.ram-mount.com
EXCELLENT mounting system
Old Apr 22, 2001 | 11:08 PM
  #15
ox's Avatar
ox
Minehunter;
I like that idea! CHEAP TOO! My kinda mount!
Old Apr 23, 2001 | 07:25 AM
  #16
rws's Avatar
rws
KISSOFDEATH
mount has never come loose...did have to epoxy the plastic wingnut back onto set screw as I over tightened it.
don't know if it will work on an Etrex...I used the GPS III dashmount which has mounting holes to bolt up to the SlipStreamer base.
Old Apr 23, 2001 | 03:27 PM
  #17
WEETOOTS's Avatar
If you want vibration dampening, a strong aluminum mount with antenna support, THIS is the best. Works with a Ram mount. This unit is a little pricey, but when you see it, you will appreciate the engineering.
http://www.cycoactive.com/gps/gps_mounts.html#iiTT
weetoots
Old Apr 26, 2001 | 11:28 PM
  #18
DesertSportsman's Avatar
Spend the $29.99 for the Ram-Mount. Its alot cheaper than replacing the GPS when the bumps get big and the thing falls off and get crushed by your riding buddy following behind on a HONDA.
No, really I have the ram-mount and couldnt be happier. Like someone mentioned, you can just purchase the base of choice for any application and move it from vehicle to vehicle. That too is worth the savings. Good luck with whatever you decide!!
Ken
  #19
Spend the $29.99 for the Ram-Mount. Its alot cheaper than replacing the GPS when the bumps get big and the thing falls off and gets crushed by your riding buddy following behind on a HONDA.
Ken
  #20
This forum is so slow that my three clicks resulted in three posts............sorry
95wolv
Sep 27, 2024 12:00 PM
EIF
Apr 20, 2017 07:15 PM
Alex G.
Sep 19, 2015 06:34 PM
chewy78
Sep 8, 2015 10:37 AM
toonces
Sep 5, 2015 01:14 PM
