'96 Xplorer 300 Rebuild
Old Oct 15, 2020 | 07:46 AM
  #21
87handmedown's Avatar
Well I put it all back together last night and went for a test drive. So far, everything seems to be working as it should. I don't appear to have any leaks or weird noises, so that's good. I'm running a premix of about 40:1 this time to protect the engine, but it's still crazy to me how it doesn't seem to smoke at all. I couldn't get a block off plate, but I did find a spare check valve and installed it. This one initially tested fine (popped open when a small vacuum was placed on it, sealed up otherwise. However, I still don't appear to be getting any oil out of the tube that goes to the carb. I opened the bleed screw on top of the pump and oil was running out, so I don't think I've got air in the system. Obviously if I'm running premix I don't need the oil injection system, but now it's really my own curiosity wanting to know what went wrong on this system that took out two motors.
Old Oct 20, 2020 | 03:28 PM
  #22
1greenhornet's Avatar
Hi, just catching up on your progress. Sorry to hear about you engine. When I put everything back together, I was worried about the oil pump as well. Ran premix for the first couple of hours but before I connected the oil line to the carb, I ran the bike at idle with a small zip lock back over the hose and manually pushed the oil pump to to the max. I could see the bag filling with oil, so I knew I was good to go before I connected the hose to carb. I'd give this a try if you are still concerned.
ADAMSQUAD
Apr 12, 2020 07:12 AM
Outsider66
Apr 6, 2017 09:47 AM
twin80's
May 4, 2010 10:58 PM
800cat
Feb 8, 2009 07:02 PM
EXPLORERATVER
Feb 19, 2004 10:31 AM
