2005 Predator 500 timing jumping 180 degrees
Old Mar 27, 2023 | 10:58 AM
polarisjunkie86's Avatar
Default 2005 Predator 500 timing jumping 180 degrees
I bought a non running 2005 predator 500. Owner said it ran last year but wouldn’t fire now. I replaced carb, fuel pump, plug, and started so far. When that didn’t work I checked timing, it was 180 degrees off. So I reset timing, valve clearances were good. Replaced chain tensioner also. Again wouldn’t start. Removed valve cover and timing is 180 off again. What could be causing this? Chain, flywheel? Thanks in advance!
getting great spark, 100 psi compression, and getting fuel. Just won’t fire.
Old Apr 1, 2023 | 03:08 AM
Turn crank through 360 degrees and timing will be right again "Homer Simpson" moment?
Cody Sipley
1) Engine problems..
Dec 16, 2019 03:43 AM
olson.a.087
Sep 20, 2019 12:43 AM
topfli8979
Jan 3, 2016 04:19 AM
aintscared05
Jul 18, 2007 01:33 AM
coyote2
Mar 21, 2001 05:12 AM
