Throttle stuck wide open
Old May 20, 2023 | 08:55 AM
Throne Go Hard's Avatar
Default Throttle stuck wide open
So my first thought was the carb but honestly I’m stumped. I have a 1996 Polaris scrambler 400 2 stroke. If the petcock gas is on it idles fine but if i turn the gas off the throttle sticks wide open but the throttle feels fine. So I thought I’d just keep the gas on (which you do anyway if you’re riding). Went to go riding yesterday and putting around its fine but as soon as I hit power band it sticks full throttle. I thought it would clear itself out but it just keeps sticking full throttle as soon as it gets going. Any ideas? I understand the etc isn’t working if it sticks wide open but I just turn the key off and it stops so I’m not too worried about that, I took the carb apart multiple times, could it be the throttle cable? I don’t understand why the throttle wouldn’t feel stuck wide open tho, any responses and thoughts I’d appreciate thank you in advance other things that may be relevant is I mix the gas because the previous owner deleted the 2 stroke oil tank so I have to mix it, did I maybe plug the oil pump back in which is causing it to run funky? Also looks like a good amount of oil is coming out of the exhaust but it still runs
Old Sep 30, 2024 | 08:24 AM
Red64's Avatar
Default Carb
My guess would be something is wrong in the carb like maybe the needle is sticking or the slide.
I would start tgere.
Redexrider
Apr 7, 2014 12:49 PM
sharktooth
Oct 13, 2006 11:20 PM
got2gofast
Jul 17, 2005 11:31 PM
bigtom0029
Jan 12, 2003 05:34 PM
soupcan
Feb 20, 2002 07:24 PM
