Gonna need a winch!
Old Dec 7, 1999 | 10:34 PM
Tree Farmer's Avatar
Boner, a couple of points. Those "rolling load" and "boats, this heavy!" figures you quote aren't as useful as maximum line pull, because the measurement method remains unclear.
I don't know what winch you're considering, but if it's an automobile cradle-type like the Warn multi-mount, I doubt your Arctic Cat electrical system can produce enough current to use its full potential.
Regarding insufficient cable for ****** block operation, auxiliary cable or rope can be used to fasten onto a pull point, such as a tree; the ****** block can be attached to the auxiliary line, and the vehicle extracted in successive "bites," shortening the auxiliary line each pull, extending the cable to tie on again.
Regardless, good luck with your new winch, where you ride, you'll need it!
Tree Farmer
Old Dec 7, 1999 | 10:41 PM
mudmachine's Avatar
David,
If you have the coins... go ahead and get the Rule 3300. Its the one winch that IS warranted to be used in "marine" applications and the motor IS waterproofed.
Sportsman 500's are great machines, but they ARE heavy.. drop that puppy in 2 ft. in heavy "I'm sucking you to the bottom" grey clay.. and a Warn just doesn't have the grunt to get you out of there. It really comes down to what you play in and how much $$$$ you have to spend...
Good Luck in your Decision.
Old Dec 8, 1999 | 12:58 AM
corncob2's Avatar
BONES:i think the #1500 only comes with a 25ft cable,The #2500 has 50ft of cable
IF YOU CAN'T PLAY WITH THE BIG DOGS STAY ON THE PORCH
Old Dec 8, 1999 | 01:25 AM
BONER's Avatar
Corncob2,
please don't take this the wrong way, but I knew that and i don't understand why you posted it. Could you explain?
I'm not trying to smart @ss so please understand my ignorance.
Old Dec 8, 1999 | 09:47 AM
  #15
kevin_staton's Avatar
Boner,
You asked a question earlier that no one answered, "what do you do if your cable isn't long enough?"
I always carry extra rope/webbing to connect to a tree so I don't have to put the hook back onto the wire (this weakens the wire because of the angle created, generally a 90 degree bend). You can always tie the rope to a tree and then the winch cable will hook onto the other end.
Most winches can pull harder than any two men. I knew a world-class powerlifter who could squat 570 lbs. If you put two of these guys together, it's still only 1140 lbs. of pull.
Always take extra rope to tie-off the back-end of your ATV. You can quickly exceed the holding friction of your brakes and tires when trying to pull someone up an incline.
As for the 30,000 lbs. winch, I would worry that it would rip your ATV in half. I don't think anyone welds a frame to handle that much force.
Happy winching!
Kevin Staton
Y2K Polaris Magnum 325 4x4
<a href="www.korrnet.org/watvclub">Windrock ATV Club</a>
Old Dec 8, 1999 | 09:52 AM
  #16
davidg's Avatar
Found a Warn U2500 for $219. It sounds too cheap and was wondering if it is for atv applications.
Old Dec 8, 1999 | 10:32 AM
  #17
corncob2's Avatar
BONES;sorry about that but you were talking about the cable being so short.was just trying to be helpful sorry.
davidg;you may find that is a utility wench they draw more juice and not really good for quad been there done that,have one in garage,that I took off.
[This message has been edited by corncob2 (edited 12-08-1999).]
Old Dec 8, 1999 | 10:41 AM
  #18
davidg's Avatar
That explains the U in U2500 I guess. :-(
Old Dec 8, 1999 | 11:01 AM
  #19
Sparke's Avatar
Well you guys have done it. Now I'm really confused! First question do I have to be careful that I buy a atv??? winch or can I get a standard winch out of the Cabalas magizine?
Old Dec 8, 1999 | 11:27 AM
  #20
davidg's Avatar
You can find the specs here for the u2500 and the a2500.
http://www.dsiwarn.com/u2500_specs.htm
http://www.dsiwarn.com/a2500_specs.htm
