Electronic throttle control?
Old May 11, 2017 | 10:22 AM
  #61
Originally Posted by Miketerk
when i say i loosened the rocker arms i mean the valves were too tight. How do they tighten on their own?
Only way is that they weren't adjusted right the first time around or were adjusted on other than tdc.
Old Jun 18, 2017 | 08:13 PM
  #62
Miketerk's Avatar
Hey was wondering if it's safe to run my 425 Magnum without a thermostat until I get a new one. Taking it out stopped quad from overheating. Also , I just put a new Uni foam air filter on and it's bogging after about half throttle. Runs better with a cheap paper filter. Is this common?
Old Jun 19, 2017 | 08:08 AM
  #63
Ok to run without one for a while until you get a new one. If the Uni is causing bogging,check that you have the correct main jet.You can drop the slide needle to see if it helps or consider dropping the main jet size.
pgamboa
Dec 24, 2023 11:52 AM
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
fordfaithful21
Dec 7, 2015 05:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
