Need help with a HO Problem
Old Aug 7, 2001 | 12:37 PM
2YellowSportsman's Avatar
A little help, please...
My 01 Sportsman is having problems. It starts fine, idles fine, and runs fine at very low speeds, but if you get on the throttle, either in gear or in neutral, it sounds like it is dying. Replace the spark plug and air filter, but nothing... it has been at the dealer's for a week and they have no clue... any suggestions?
Old Aug 7, 2001 | 01:13 PM
Thor's Avatar
If it starts fine, idles fine and rejects application of throttle it sounds like a fuel starvation problem or a misadjusted ETC control.
Check the following:
kinks/blockage in the carburetor vent tubes
water in the fuel bowl
improperly adjusted ETC control
plugged pilot or main jet
low fuel level in the carburetor caused by improper float settings
These are the obvious easy things. Ask your dealer if he has performed these tests. Good luck[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 7, 2001 | 01:31 PM
Farmr123's Avatar
Check all that Thor suggested.
One thing to try. Hold down the override button. Now will it rev up?? If so, it is likely either the transmission range sensor or the rev limiter.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
