K&N Filtercharger
Old Sep 15, 2001 | 02:24 PM
scrambler123's Avatar
Has any one used this on a scrambler 400 and how did it perform.
Old Sep 15, 2001 | 10:12 PM
Ronnnnn's Avatar
I have it. I threw the airbox away, put the k&n on, put an outwears on.
I have no regrets.
Old Sep 15, 2001 | 10:19 PM
KevinM's Avatar
It works good until it gets wet and causes scratches on your piston. I don't know if I'd recommend it to anyone who occasionally rides in a little water, I think its better suited for riding in the sand.
Old Sep 16, 2001 | 01:00 AM
modquad's Avatar
I think there are two different grades of outwear. One is more water resistant than the other. Also when they start to wear, they can loose some of this resistance. Like Ron said, they work great, just use a little caution in blasting into water holes.
KT P.S. Don't buy the K&N cleaner, just the oil. The cleaner is the same as 409. Keep a gallon ice cream pail with the lid. Keep your 409 in there for multiple uses.
Old Sep 16, 2001 | 09:37 AM
500DUSE's Avatar
Kevin
Now thats not good to hear.
I just got the k&n filter with outerwears and jetting needle
for my 01 sp,and I ride in water alot.
Are you saying this is going to do more damage then good?
Or did I misunderstand ??
Old Sep 16, 2001 | 12:03 PM
KevinM's Avatar
500duse, the K&N filtercharger replaces the airbox with only a filter and outerwear leaving it pretty much unprotected. As long as you leave your airbox on, a K&N should never give you any trouble.
Old Sep 16, 2001 | 02:08 PM
500DUSE's Avatar
I got ya
Thanks
Old Sep 16, 2001 | 03:40 PM
highoutput2cycle's Avatar
go for it (no airbox),you'll have great torque gains and response all the way,but if you have a 42mm carb,DON'T do it cauze there will be too much air to the crank and not reliable at all...
be sure the make the proper jetting changes by checking spark plug color all the way to the top.enjoy!
AdamScramblr400
Jan 31, 2002 05:43 AM
AdamScramblr400
Dec 17, 2001 10:37 PM
scotto
Aug 23, 2000 01:18 PM
Hawkman
Jan 17, 2000 10:04 PM
trailblazer00
Jan 4, 2000 12:19 AM
