Transporting two machines in pickup
Old Nov 24, 2001 | 06:14 PM
ftwflh's Avatar
Trailer is the way to go i bought a new 7 1/2 x12 with a drop gate for $650.
Old Nov 25, 2001 | 09:49 AM
biggy's Avatar
sorry i fixed the addy.......lol
Old Nov 25, 2001 | 06:04 PM
Svalbard11's Avatar
You said taht you can just haul 1 trailer in Minnesota. Where can you haul 2 or 3 trailers?
Old Nov 25, 2001 | 07:21 PM
400L's Avatar
Yes you can, if you can lift the end. Make sure to cross all straps, I'd double them. Do you need to use your hitch for another trailer? Or are you trying to avoid the cost and mess of a trailer? If you want another idea, look in Northern Tool's catalogue for a "bed extender" Basically a 2x2 steel tube that inserts into the receiver, has another 2x2 upright, and another 2x2 flat with the truck's bed. Then just use a couple of 2x12 planks to from the front of the bed to the 2x2. You can haul two SP end to end.
Old Nov 25, 2001 | 10:10 PM
  #15
yamahagye's Avatar
Depending on what size truck you have, you might be able to put the loading ramps on the side of the truck leaning against the bed, then load the quads in sideways with two of the wheels from each quad resting on the side of the pickup bed.
Old Nov 26, 2001 | 09:14 AM
  #16
Michimaniac's Avatar
needtoys,
I saw one of those sideway/on top of the bed racks down at the H/M TrailFest. SCARY was all I thought of, though I'm sure it'd work just fine with plenty of storage in the bed(I'd slow WAY down on the curves with two SP's up there!).
John
Old Nov 26, 2001 | 11:00 AM
  #17
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
You can pull MORE THAN ONE trailer in Texas.
Old Nov 26, 2001 | 11:10 AM
  #18
biggy's Avatar
there is alot of states that it is legal to pull 2 trailers.
Even minnesota but here you can only pull two trailers if the first one is a fifthwheel
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Dewhound
Apr 20, 2017 02:25 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
salixair
Nov 3, 2015 08:25 AM
cornermike
Sep 10, 2015 08:30 AM
