Engine dies when put in reverse
Old Mar 19, 2002 | 01:33 AM
Yarddog's Avatar
I have a 95' Sportsman and for whatever reason,when i put it in reverse the engine dies unless i use the override button, which Ive learned to live with. Herelately it has gotten worse: Now sometimes when you put it in reverse and hit the override button it spits and chokes bad thru the exhaust and want come close to backing up. Now I can't live with it being this bad. Is this something I can fix or do i need to take back to the dealer$$$$$. I know somebody out there can help. Thanks in advance. Yarddog
Old Mar 19, 2002 | 09:30 AM
riderrideshard's Avatar
mine did the same thing found the reverse limiter box was bad . replace the box and it should work fine!
Old Mar 19, 2002 | 06:27 PM
MUDFUN's Avatar
You might try bypassing the switch and see if that clears up the problem, if so then replace the switch or live without it. I'm getting ready to bypass it on both mine.
Old Mar 20, 2002 | 01:20 AM
Yarddog's Avatar
Riderrideshard & Mudfun, I have two ??'s,one how much is the limiter box and where is it located; two, How do you bypass it?
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 10, 2015 12:42 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
