Removing labels
Old Mar 19, 2000 | 06:45 PM
SWAC1's Avatar
I know this topic has been posted before, and I posted to it as well. Unfortunately the post I added did not refer specifically to the labels on the plastic on a Polaris. I tried a heat gun to peel the labels off, but the label is so thin, it just breaks when you try to peel it off. So whats the best way? Chemicals? Belt Sander? hehe
Old Mar 19, 2000 | 07:55 PM
Four_Play's Avatar
You might try a pressure washer or stop at a car wash. Once I got to close to a sticker on mine and it took a nice little chunk of it off.
Old Mar 19, 2000 | 08:51 PM
SportsmanDave's Avatar
I used a hair drier and kerosine. My buddy used cooking oil? said it worked good?
Old Mar 19, 2000 | 10:21 PM
snakechaser's Avatar
high pressure steam cleaner workz the best, then a lil solvent to remove left over glue
Old Mar 20, 2000 | 06:28 PM
QuadBuster's Avatar
Hell, I used the Hair drier too and it worked pretty well. YOu have to get the sticker pretty hot though. When they quit breaking off in large peices, and started coming up in jiblets, I put 2500 psi of water to it and took the rest off. I use carb cleaner to get the access glue off. The carb cleaner also leaves a good shine.
EC
Old Mar 20, 2000 | 06:53 PM
quad_man's Avatar
The stickers will break unless you have it heated up good, and you move SLOWLY when removing them.
I used the heat gun to intentionaly remove some stickers, although I accidently removed some off the hood and side with brake fluid & water hose.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
