Polaris Explorer 500 1997, gas problems, help please
Old Aug 25, 2002 | 10:28 AM
Allan's Avatar
Hi, I think that I picked up some gas at some time that had water in it
and I didn't use the bike for two weeks after that. When I
went to use it it ran well for about a mile then just stopped. I could not get it started anymore so I purchased
water remover and injection clear for the gas. A couple of days later I got it started but since then when I throttle too much the engine just wants to die.
WHAT CAN I DO TO FIX THIS PROBLEM?
Old Aug 25, 2002 | 08:47 PM
upnort's Avatar
check plug? Had that problem and all it was is the plug had fouled.
Old Aug 26, 2002 | 09:18 AM
Allan's Avatar
I have changed the spark plug.
Old Aug 27, 2002 | 11:03 PM
700sportsman's Avatar
Remove carb and inspect the needle and seat I have seen many worn out and will restrict the flow if they arn't centered properly. Check fuel filter and air filter. Also if you suspect any water you could add a small amt of polaris isopropal into the fuel tank, works great in the sleds. Good luck.
neilbedwell
Nov 10, 2018 11:02 AM
TJM
Jun 11, 2015 01:28 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
kencbs
May 23, 2015 05:29 PM
blackmagic
Feb 26, 2000 09:27 AM
