Bubba or Modquad
Old Nov 30, 2002 | 03:18 AM
dillas23's Avatar
Default Bubba or Modquad
Hey guys,
Can you answer a question for me? On a 86 250 Trailboss, did they have rear brakes? Or did the brakes for the rear work off the disc by the tranny.
Lee
Old Nov 30, 2002 | 04:43 AM
modquad's Avatar
I would guess....that means I don't know....that it would be up by the trans, the earlier machines had that configuration. Maybe Bubba knows, or someone has one or access to a parts/ service manual.
Sorry,
Ken
Old Nov 30, 2002 | 07:35 AM
Mike Chero's Avatar
dillas23,
Yes, that is the brake mounted on the out put shaft near the countershaft (front) sprocket. This is a good idea for two reasons. #1 it lessens unsprung weight. The second reason is that it tucks the brake up safely from rocks and other debris when riding. The only down side is that if the chain breaks you have no back brakes .
Old Nov 30, 2002 | 09:54 AM
Farmr123's Avatar
I once rode an oooooolllld Polaris, no idea what model or year, other than it had 4 wheels. The rear brake was actually on the INPUT shaft of the tranny. It was kind of wierd, having about double the braking power in Low range than in High. On a more positive note, if you gassed it in Neutral, you could tap the rear brake, and get the pulleys to stop turning a lot quicker when you wanted to get it into gear. Good thing, too, as it shifted like a model A Ford.
Old Nov 30, 2002 | 12:01 PM
Bubba297's Avatar
Sorry Lee, a little before my time dealing with these. I would be pretty sure it definitely wouldnt have the brakes on the rear axle, but as said before on the transmission somewhere. Bubba
Old Nov 30, 2002 | 12:57 PM
dillas23's Avatar
I checked out my Haynes manual last night and got the answer. I just had to search a little for it.
fastpred500
Jun 17, 2003 10:58 AM
Stickhauler
Apr 25, 2003 07:34 PM
NCScrambler
Mar 3, 2003 09:49 PM
2manytoys
Jan 28, 2003 04:01 PM
2manytoys
Dec 8, 2002 04:42 AM
