starter problem
Old Mar 11, 2003 | 09:18 PM
MAGMAN325's Avatar
Default starter problem
i have a 1998 polaris xpress 300 and the starter aint workin right.i have a idea what problem is but want some feedback.this what it does when you go to start it for the first time of the day it makes a clickin sound and wont turn over and its not the batt or anything like that because i checked that but then after you get done riding it and turn it off and then start it again it starts right up.I think it is the bushes in the starter but i dunno.help me out please.thanks
Old Mar 11, 2003 | 09:44 PM
Conkster's Avatar
That would be my quess because i have a tb and when my brushes went out it did the same thing.
Old Mar 11, 2003 | 09:47 PM
Crawdad's Avatar
Chances are it's your brushes that probably need replacing. You can get a brush kit at the dealer and they're easy to replace once you get the starter out.
If you ride in alot of water you need to drain the water out of your starter occassionally as well. You should also check your connections at the starter relay switch too.
The starter on my '98 just died though and it was the brushes. If you pull the starter and remove the end of it you can see if the brushes are bad.
Old Mar 15, 2003 | 01:47 PM
Brute's Avatar
I also have a '98 Express 300 that had the same problem. It is most likely the starter brushes, but removing the starter is rather difficult. To get to the starter on an Express, you MUST remove the recoil starter housing to access two bolts that hold the "drive" end of the starter in place. Then you must remove the drive and driven clutch plasic housing to get to the clutches. Remove the drive clutch. That requires a special puller. Remove the driven pulley. No puller required (for me anyhow). Then remove the inner plastic housing. You'll then see two 10 mm bolts that affix the other end of the starter to the frame. Remove these bolts, remove the #6 wire from the stater solenoid, then remove the two bolts on the recoil starter end, and the starter will come out. You'll probably find the starter drive gear will not come out with the starter, but just reach back in there and pull it out. You cannot, I repeat CANNOT remove this starter from the underside of the machine. I just performed this job on mine. If you need any further help, please email me. I'll gladly provide any additional help if you desire. (rcruff2314@aol.com)
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
