polaris starter
Old Apr 27, 2000 | 02:25 AM
Charlie's Avatar
You can easily change the starter drive by removing the flywheel with a puller. The drive can also be disassembled and lubed. Not many pieces are servicable except the garter spring. The one way clutch and or rust has always been the problem in my experiance.
Idle speed could be the culprit if the drive seems to hang up after starting. Too low of an idle and the drive has trouble kicking out. Bump up the idle to 1100 or 1200 RPMs where most Polaris 4 strokes should be set. This also helps make shifting easier but too many and it gets hard to shift again.
Old Apr 27, 2000 | 07:02 AM
Zman's Avatar
Stick,
I went though all that,cleaned, took apart and lubed. Then I replaced the bendix, Worked but made funny noises.
Now last nite I replaced the whole thing, starter and drive. It's never sounded better, quit and smooth. Hope this is the lucky one that lasts!!
Old Apr 27, 2000 | 07:28 AM
Gov's Avatar
Gov
DCop
My 2000 sportsmans starter does the same as yours.
Old May 2, 2000 | 03:11 AM
alelston's Avatar
My 97 Polaris Explorer 500 starter has always worked like yours, i.e. it stays engaged for a second or so after the engine starts. Has not caused any problem.
Reactant
Mar 30, 2022 02:08 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
tweeder
Jul 5, 2015 01:57 PM
