400 xplorer compression
Old Apr 17, 2003 | 05:51 PM
trenchdigger's Avatar
Default 400 xplorer compression
can anyone tell me what compression i should have on my 2000 400 xplorer,i have 3100 miles on it and
it shows 105 pounds on my tester is this sufficient. i have also ordered a aaen top end pipe for it and clutch kit i would like to get some feedback on this set up .Any info. would be much appreciated
Old Apr 17, 2003 | 05:56 PM
NCScrambler's Avatar
Nope, not enough compression. 115 is the min. That is a good set-up for the 400, you will notice a big difference after you rebuild the top-end. Don't go with the Polaris piston, get a Wiseco and use Cometic gaskets except for the base gasket, you will want the Polaris for that one. The top end is cheap and easy to re-build by yourself.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
