help sportsman 90
Old Apr 19, 2003 | 07:27 AM
lt500's Avatar
Default help sportsman 90
[img]i/expressions/face-icon-small-disgusted.gif[/img] 2000 sportsman 90 will only run when holding start button on let start button out machine shuts off replaced on/off switch start button unit and battery also electric start not working starter motor shorted out? solenoid switch gone?where is it?thanks
Old Apr 19, 2003 | 05:28 PM
lt500's Avatar
anyone with any ideas?please help
Old Apr 20, 2003 | 12:39 AM
Northstar2's Avatar
dont really know much about that machine, but I was wondering, when you hold the start button and it runs, is the starter staying engaged? It sounds like a solenoid problem to me. shouldn't be hard to find and change. good luck
dont the kids ones have a tether kill switch? could be something in that circuit...
Old Apr 20, 2003 | 08:01 AM
lt500's Avatar
the starter is not staying engaged it will not do anything i hold the start button and kick start the machine it runs fine but let off start button and it shuts off i have bypassed tether cord with same results (now reconnected tether cord)thanks
Old Apr 21, 2003 | 04:42 PM
lt500's Avatar
back to the top any ideas ?thank you[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 22, 2003 | 10:51 AM
Pechmial's Avatar
Clarify this for me, you are pressing the start button on the handle bar and the starter is NOT turning?! You should not need to use this button at all if you are kick starting the machine (it only operates the electric starter). Our SP90 starts all the time with a kick but rarely with the electric starter now that we've upped the piston/cylinder size.
As to your problem, I suspect the problem is in the on/off switch. It has three positions, (off, on, back to off) in that order left to right) and it may not be holding in the "on" position unless you hold it in place. If you're actually pressing the starter button and this works, I suspect something is seriously screwed up in your wiring (perhaps the starter button, which is a "momentary" type button is wired to your where your "run" switch should be wired to).
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
