SP 500 AWD Reverse Problem
Old Apr 23, 2003 | 12:44 PM
ChiefUllig's Avatar
Default SP 500 AWD Reverse Problem
Hello... I am having problems when I am in AWD then want to go into reverse. From what I understand the front two hubs are supposed to disengage. But, when I start backing up one stays engaged always and the handle bars pull hard to one side. The manual says this will happen occasionally. This happens to me every single time. Has anyone had the same experience? I just picked up the quad last weekend. The only the other problem going on is once the quad warms up (after 20 minutes or so) I get a low pitch screaching noise when giving it throttle from take off. Other than that I am enjoying the SP 500. My uncle is a firm believer in Polaris, he's got Snowmobiles, Jet Skis, and Quads all by Polaris. He sold me on them. Thanx Guys....
Old Apr 23, 2003 | 04:05 PM
NCScrambler's Avatar
If your machine is that new shouldn't it be under warranty? If so, I would tell the dealer about it and make them fix it. The squel is pretty normal, normally that sound comes from the EBS kicking in. I would check your oil levels to be safe though. Check the tranny level and the front gearcase levels. You could add a slight amount of hub oil to the front hubs to take care of the 4WD sticking problem, but like I said, if it is under warranty, why bother. Make them make it right. Welcome to Atv Connection.
Old Apr 23, 2003 | 04:30 PM
ChiefUllig's Avatar
Thanx for the advice as I am getting new to all this. I'll make sure I take it in to the dealer before that 6 month Manufacturer warranty expires. I'll check all my fluids tonight. Thanx again
Old Apr 23, 2003 | 04:35 PM
No problem. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 24, 2003 | 07:44 AM
upnort's Avatar
I agree, as long as it is still under that lond 6 month warranty get it in there, I procrastinated and mine is now out of warranty, should have taken it is for an irritating rattle with the racks.
Firefighter400
Oct 8, 2022 06:38 PM
Reactant
Mar 30, 2022 02:08 AM
Captjay
Jul 23, 2015 12:33 PM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
