apc clutch kit 600sp
Just bought a 2004 600sp 2 weeks ago i just love the machine,and i want to know about a utility clutch kit is there a big change in rpm engagement I dont want a high engagement is that possible and I dont want to lose top end speed. Witch kit is better, is apc good.Here in canada the kit is 280.00$. any comments [img]i/expressions/face-icon-small-confused.gif[/img]
http://www.heelclicker.com/
These are fully adjustable so you can have any engagement or power curve you would like. I have one in my 700...
I have a 2004 500 H.O. ,which I want to put a heelclicker on ,which set up or weight set do you recommend starting with .I really would like it to be quicker and hit harder at the start,but don't want to lose topend if possible.Thanks.If you have already tried several setups , maybe you could save me some time.
thanks I wasn't sure if in the directions they had a setup listed that they had probably tested and thought it was the best overall.In your opinion do you think it would do my 04H.O.500 good'As I had installed an EPI kit 0n my 2000sportsman 500and was disappointed
If you want full power you can put a spring in that would allow you to be in the power band when the clutch engages (really jerks you & goes) or you can have the clutch engage just off idle(good for rock hopping etc,) and very smooth engagement as compared to higher RPM engagement. You can adjust the 3 weighted arms to hold longer at different speeds to tailor to your type of riding...
The directions list setups for several models & for larger tires. You can call & talk to DAN at heelclicker & he will help you with any questios or problems. HEELCLICKER.COM has excellent online manual & step by step install instructions. (Discount price of $150 U.S. if bought thru ATVNATION)...They stand behind their products %100. No hassle with guarantee...
I went to atvnation to get the heelclicker thru them at the discounted price ,but couldn't find anythimg but the link to heelclicker .Also I know you said you kept the stock primary for lower RPM engagement ,I will do the same, but tell me about the secondary spring setup and how to do it I heard it has to be turned and set to the proper amount of tension? Thanks for your time!
Go to the POLARIS section & you will see several things about HC at the top of the FORUM. The secondary spring is ready to install, no trimming. Look on the HC site for pictures of install step by step under topic 24/7 Tech Support. Call DAN & he will tell you anything you need to know, even about the Grizzly he took with Bow & Arrow from close range! I have a great dealer here (Prescot Valley-80 miles)& he did most of it for me...
cdstang
Aug 31, 2015 07:52 AM
