trailboss misfiring at full throttle...any solutions?
Old May 6, 2003 | 01:51 AM
Iszy's Avatar
Default trailboss misfiring at full throttle...any solutions?
My 2002 trailboss runs just fine until I try to run it top speed. When it picks up speed I can hear a faint miss in the motor like its trying to cut out. any ideas why its doing this? I have never changed the spark plug. is it time to do it? I have had it just over a year and bought it new. Any info would be greatly appreciated.
Old May 6, 2003 | 12:08 PM
NCScrambler's Avatar
Yes I would say change your spark plug and make sure your air filter is clean. Also make sure your plug cap is in good shape and seated good. If that doesn't do it, it is probably a carb , vent hose, bad gas problem, or gas delivery problem. Start with the plug and work to the other things.
Old May 6, 2003 | 04:29 PM
Iszy's Avatar
Thanks for the reply,
I was also going to ask if anyone else has had a problem with their trailboss bogging down once its warmed up and been running for a while. I was climbing a few hills and all of a sudden it bogged down and wouldn't run until I choked it. This same problem happened when I was riding in the woods next to the snake river.
Old May 6, 2003 | 07:32 PM
CrispyCritter's Avatar
Did it just bogg down? If it did, how old was the Gas? I had the same problem before and after adding new gas it ran fine.
i do have a 500 Scrambler that runs like sh*t and have yet to find out what the problem is..
Critter
Old May 7, 2003 | 01:12 AM
Iszy's Avatar
When my tboss bogged so bad I needed to choke it; it did have some older gas in it. It wasn't so old it should have been a problem though. My main concern is the miss the motor has when running full speed. I'll pull the plug over the weekend and take a look at it. The past weekend I had filled up with fresh gas and it was still missing just a little.
dan.
Johnny Mac
Aug 15, 2019 03:13 PM
dannytas
Sep 26, 2017 06:31 PM
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
