Are 1988-1990 Big Bear Front CV Axles Reversible?
Old 05-25-2017, 03:25 PM
lciummo's Avatar
Default Are 1988-1990 Big Bear Front CV Axles Reversible?
I need a new left side but accidentally bought one for the right?
Later mid-90's models definitely seem to use the same axle on both side - not sure on mine.
Thanks
Old 05-25-2017, 05:39 PM
Ajax's Avatar
if you have it out cant you just compare the 2 side by side?
Old 05-25-2017, 05:43 PM
lciummo's Avatar
It's not out yet, and I haven't received the right side to compare yet.
The left also only really needs a CV boot, so I either have to order he boot ASAP or miss my weekend "install" window.
lc
Old 05-26-2017, 09:37 AM
Ajax's Avatar
Looks like 1989-1996 "front axle is the same..
https://www.americancvstore.com/1989...lete-axle.html
Yay google..
Old 05-26-2017, 09:41 AM
lciummo's Avatar
Can't really tell via the Yammy part nums. They break out every part in the axle into separate parts. Maybe a non-OEM web site might be able to tell but I haven't found one that does that.
The used one arrived last night - nothing obvious on it looks like it wouldn't fit - splines on both ends. Maybe the hubs threads are reversed or something.
Thanks
lc
Old 05-27-2017, 10:39 AM
The only difference would be the length, some front diffs are not dead bang in the middle, so the bike needs a long and a short drive shaft. My guess would be same length both shafts. Check them side by side, don't forget the inner joint can slide in and out a couple of inches.
Old 05-27-2017, 12:02 PM
lciummo's Avatar
Just got it out. Didnt know all the diff fluid would drain out. Seems to be exact match.
Should the fluid have leaked out?
Thanks all for the research too.
Old 05-28-2017, 03:00 AM
Yes some diff oil leaks out as the level should be slightly above the bottom of the drive shaft. Top up after installing.
