wont idle
Old 05-29-2017, 04:58 PM
jeremy420's Avatar
Default wont idle
And what screw do i turn on the carb to make it idle. The one thats in the carb or the one with a hose on the end and what way do i turn it
Old 05-29-2017, 04:59 PM
jeremy420's Avatar
Its a 2004 honda 300 ex
Old 05-29-2017, 07:58 PM
papa hogg scoot's Avatar
To increase idle speed turn the one with hose on it clockwise
Old 05-29-2017, 08:01 PM
Photo number 11 is Idle speed screw in above post
Old 05-29-2017, 08:28 PM
jeremy420's Avatar
Originally Posted by papa hogg scoot
Ok thank u for all the info so i should start it and keep turning that screw tithe right to get it to idle right. And i changed my carrier barring and now my back brake wont work. U know why
Old 05-30-2017, 09:50 PM
Your foot brake pedal? or parking brake? Did they work before removal? Did you get grease on it from handling carrier assembly?
Old 05-30-2017, 09:53 PM
Let engine warm up good an yes turn the idle speed adjustment screw until you get the idle you looking for.If have to turn alot like 6 or 8 turn then something wrong like screw to short or you could have fuel and air mixture wrong or air leak
Old 05-31-2017, 04:43 PM
jeremy420's Avatar
No theres no grease on it. I cant even see the caliper clise against the disc. Does it take brake fluid and if so where does it go
Old 05-31-2017, 10:19 PM
Yes brake fluid dot 3 or 4 be fine. hard to say were the fluid is going, do you see an leak or fluid on ground or pavement? leak at master cylinder or caliper?
