need a little help with electrical,,,,
Well the complete bodged up mess of a wiring loom is all too familiar with Chinese/Taiwanese bikes. The stator doesn't look to have a separate exciter coil, which probably means DC ignition. This is the same as a 1980s car and would use the 4 pin CDI. The high tension ignition coil on a DC system is usually wired with a live from ignition switch, and a pulse wire from CDI. On AC systems the ignition coil has a pulse wire from CDI but other thin wire on it is earth.
