660 grizzly basegasket
Old 11-12-2018, 12:46 PM
200es's Avatar
Default 660 grizzly basegasket
I have a 2003 660 grizzly. My basegasket went a couple months ago. I replaced the gasket drove it and it blew the gaskets out the side. I tour it apart again this time used a metal gasket. Torqued the cylinder bolts to 50lbs and it immediately started pouring oil out over the floor. I dont get it new gaskets all bolts are tight and still leaks oil
Old 11-12-2018, 04:25 PM
Jered651's Avatar
Does the 600 have an oil passage that comes up threw the cylinder? Warriors and others all do. You might have forgotten the O ring between the jug and the crank case
Old 11-13-2018, 02:45 PM
200es's Avatar
Default 660 grizzly grizzly basegasket
Yes it does have the oil passage. Found my problem. The threads in the cases stripped out. Well actually just one stripped. The one in the front left corner . I thought about using a time-sert but I'd have to remove the dowel pin in order to make it fit. Do those pins help keep the gasket in or are they just there to aid in assembly to hold the gasket from moving while you put it together
Old 11-13-2018, 04:21 PM
Jered651's Avatar
If you use a heliacoil you should be able to use the dowel pin. It does help hold the gasket yes but it is really to make sure your jug or head is aligned properly. I'm not sure I would run one without it. It might be fine without it though its your call. Take it to a machine shop have them put in a heliacoil and use the same bolt. Might cost you a little money but should work.
HiTekRedneck08
03-30-2008 10:36 AM
ProEMTPFF
02-16-2008 07:15 PM
grapestomper
09-06-2005 10:54 PM
WinterRules
08-27-2003 10:59 PM
Quick Reply: 660 grizzly basegasket
