Engine will crank but wont turn over
2011 Polaris Sportsman 800 EFI
So i was tiling some stuff the other day and i took a break and guess what the atv wont start. This is what i have done so far.
Checked battery, starter solenoid,Fuses, Wiring harnesses, Starter bendix. Fuel lines for fuel. Fixing to check fluid pressure as soon as i find a guage. However i dont believe thats an issue as squirting fuel into the spark plugs well doesnt seem to make it turn over.
Checked for spark and changed spark plugs as they appeared a little foul still no change.
No error codes on diagnostics.
I am not sure where to go from here.
Any and all suggestions welcomed.
You state it cranks so it is probably not the battery or Starter. Is the plug getting power? Check all the connections. And if you do not have proper voltage the machine wont start.
GLI
14
03-29-2012 12:08 AM
albaBANSHE
12-01-2002 03:44 PM
