Xpro 125cc
It’s all on the left side except for ignition switch. I’ll check it out today
has no spark either
Im thinking the solenoid is bad
Headlights still won’t come on. Does it have to be running for those to work?
If the lights are AC then all bets are off, your fault could be anywhere. Though, if the ignition is AC, the plug should spark when the engine is spinning, as long as you did turn the ignition on first. Without seeing the bike, or a wiring diagram I can't help much.
To test the solenoid, check if power is getting to both thin wires that go to it when you have ignition on, brakes on, out of gear and are pressing the start button. I use a 12v incandescent test lamp for this, as a lamp tests for power, not just volts.
MikeTexas (Today)
jomiller97
11
07-13-2018 07:58 AM
