Sport Quads Discussions on sport quads.
z440 kit
Old Jan 8, 2004 | 01:09 PM
Flynbryan's Avatar
Default z440 kit
Doug Gust doesn't seem to have to terribbly much luck with them..... But then again too he's running a full tilt top performance motor, and hes seriously aggresive compared to you and I. Motor reliability is DIRECTLY linked to motor maintnance. If you ignore oil changes, compression checks, and valve adjustments...yes you do have a ticking time bomb. But if you stay on top of maintnance you will normally be alerted of problems before it creates engine failure. Although anytime you pump up compression, and have aggressive cams your going to shorten your top-end rebuild times. As others have said on here "If you wanna play, you gotta pay" Its just up to you on if the extra hp. is worth the extra maintnance. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 8, 2004 | 09:23 PM
bulldogz400's Avatar
Default z440 kit
No problems here with my 440. Only complaint is cold starting is a little harder, (due to the HotCams without a decompression pin that the stockers have), but otherwise I can't wipe the smile off my face! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 12, 2004 | 12:06 PM
BlueZ440's Avatar
Default z440 kit
Do any of ya'll have a loud knocking noise coming from the head?? Also my bike won't idle right, any suggestion? I tryed the idle screw and I got a 160 main Jet and it still won't idle right. I have so far put a Wiseco 440,with Hot cams and yoshi. Please help.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 12, 2004 | 07:31 PM
z838mx's Avatar
Default z440 kit
if it has a loud nocking then something is not right. there is no reason to have a knocking noise in this motor if it is installed corectally.
Old Jan 12, 2004 | 08:59 PM
  #15
BlueZ440's Avatar
Default z440 kit
thanks, any ideas? and why it wants to die when a give it full throttle.
Old Jan 13, 2004 | 12:27 AM
  #16
z838mx's Avatar
Default z440 kit
dont know who put it together? did you do it or did a friend, shop do it? sounds like timing could be off or a bent valve.
Old Jan 13, 2004 | 02:46 PM
  #17
BlueZ440's Avatar
Default z440 kit
my friend did it. I had the sleeve put on by a machine shop. my friend was saying something like it's maybe the exhaust hitting the pipe. Does that sound right? If the timing is off, would that make my quad not idle right or what happens?? thanks for replying back man. I really need someones advice until he can come over and check it out.
BigDaddy331
Jan 9, 2006 12:39 AM
BlueZ440
13
Sep 27, 2005 06:26 PM
crispy
Sep 20, 2003 12:23 PM
Raptorx44
Jul 9, 2003 06:36 PM
