Sport Quads Discussions on sport quads.
Is deal on 2 Mojave's ($1,800) good? Any advice?
Old Apr 1, 2004 | 09:38 PM
MojaveMan88's Avatar
Default Is deal on 2 Mojave's ($1,800) good? Any advice?
Thanks for the heads up! The guy told me he did the axle bearings on one of them himself. I guess this is a problem with all of them. How do you know when they're going? If they do need replacing is it a major expense? I'll keep an eye/ear open for the problem. Thanks again.
Old Apr 1, 2004 | 09:50 PM
Thanks for the reply! When I test ride the Mojaves when I go to pay for them, is there anything that I could look/ listen/ or feel for to forsee a topend problem? When I test drove them originally, I used low-end and mid-range. The guy said I could go down to his field and open it up but I didn't. Thanks.
Old Apr 1, 2004 | 09:54 PM
Thanks for your input. I told the guy we would take them. I did not give him a deposit though, he said it wasn't neccessary. We'll pick them up within about a week and a half.
Old Apr 1, 2004 | 10:17 PM
Chris142's Avatar
I wouldn't call them "Major" problems. More like annoyiances. The intake cams do go flat sometimes, not every bike though. Some run 4-ever w/o losing a cam. Also The intake valves sink into the seats , again not every bike but quite a few.
When/if you buy the quads I'd adjust the valves first thing. Then every 6 months and you should be ok. I think the flat cam deal starts with the intake valves sinking into the seats because every one I have seen that had a flat cam had the messed up valves too.
My cam does have some wear that can be seen. It seems to have stopped......so far anyway. I'm keeping an eye on my oil filter for major metal shavings and when it finally goes I'll rebuild it.
Something I have noticed that I don't understand. The bikes that get regular dino oil seem to not have cam problems. Those of us that run the hi-dollar synthetic oils have cam problems.
Weird.
Old Apr 2, 2004 | 03:46 AM
  #15
rescuediver's Avatar
Mojaveman, You got a great buy on the mojaves. You shouldn't have problems getting parts for them. They are easy to work on to, get yourself a manual. I like the supertrapp on my mojave and the k&n with the stage 2 really woke her up. Just my .02 cents. Lt. Dan
Old Apr 2, 2004 | 06:47 PM
  #16
sandblaster360's Avatar
good deal man.
take care of em and when you get better you can sell em and get some bigger bikes.
Old Apr 3, 2004 | 12:16 AM
  #17
anyrider00's Avatar
Those will be good to start on but later on you will be moving up to the bigger ones.
Old Apr 3, 2004 | 01:31 AM
  #18
huskerjim's Avatar
I appreciate any advice guys! The deal offered us is, <u>2- 1988 Mojave 250's</u>, two serial numbers apart, one w/ rack, both look good, minor crack in left rear fender of one. One had carb work last year (plastic gasket replaced at intake??) because it was difficult to start, runs well now. The other has a high idle that is difficult to adjust out with adjustment screw on carb, but runs well otherwise. Both run well considering they have sat all winter, with same gas, oil, plugs, airfilters, from previous season. Both appear stock, good rubber on both, two owners; first were older couple used for trail riding in national forest. They are to be used by my thirteen-year-old son and me for aggressive trail riding. We are not big people, they seem to fit us well. $1,800 for both, is it a good deal?? Again, thanks for any input.
Mojave Deal
I know mojaves I had 3 of them with the problems that you say they are having plan on putting Intake cams in them they are wiped out, 155 bucks for each the exhaust will be fine also remember the 1988 had soft valves you may need to do valve jobs on both as well the valves are 30 a piece and machine work $135, so in short you problaby are paying about what they are worth, if you know them much ask them if you can take the valve covers off and look at them if they aren't wipe get after it if they are make a better deal with them! Can't lose either way, any question PM and I can tell you details of things to look for.
neilbedwell
Nov 10, 2018 11:02 AM
tmoose
Jun 30, 2015 08:28 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
