Sport Quads Discussions on sport quads.
please help, engine only giving out 50% power?
Old Oct 25, 2005 | 07:29 PM
hotlicks's Avatar
Default please help, engine only giving out 50% power?
Just got a 87' 230 quadsport that had been running and the chain broke and busted the side cover. It sat for a year in a shop. I replaced the side cover tested compression , cleaned carb etc. etc. Bike throttles along at 50-70% power and if you keep the throttle held at the halfway point the power kicks in with 100% power off and on like it is starved for air or is getting too much fuel. If you justs give it full throttle from the start of each gear it is boggy and slow. I know this bike has more response and power than it is showing. I am frustrated and can't figure out what to do. Any help will be appreciated.
zach
tzhill@bellsouth.net
Old Oct 25, 2005 | 09:32 PM
warriorguy22's Avatar
try cleaning the air filter good
Old Oct 26, 2005 | 12:04 AM
RDZ350's Avatar
Warriorguy is probably right.Might try a new plug.Probably need to try using fresh gas too.
Old Oct 26, 2005 | 09:59 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Yeah, did you put new gas in it and drain the old? Also, one of your jets could still be plugged up, you might want to take a better look at them.
tweeder
Jul 5, 2015 01:57 PM
bikedad3
Jul 2, 2015 02:15 AM
toonces
Jun 30, 2015 11:19 AM
jonathongolden250
Jun 24, 2015 10:09 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
