LT250R problems(please help)
Old Jun 12, 2003 | 12:16 AM
howler666's Avatar
Default LT250R problems(please help)
My LT wont idle and to start it u need to pull it fast with another bike, i dont now wuts wrong. im think its the piston, maby low compresion.
PLEASE HELP
Old Jun 12, 2003 | 12:46 AM
LT250RSuperstar's Avatar
When did this start happening??? Does it smoke really bad too?
Old Jun 12, 2003 | 09:37 AM
HUEDOGG's Avatar
clean the carburator out COMPLETELY!
Old Jun 12, 2003 | 04:36 PM
dual-sporter's Avatar
after you finally get it started does it run fine & start easy?
when is the last time you did a top end ?
Old Jun 12, 2003 | 06:17 PM
howler666's Avatar
about 2 yrs ago but it only has about 25 hours on it, and i just check the piston before winter and havnt really rode until last week end, and it it only took 2 day to go from, bat out of hell to sh*t on a stick, lol, please help
Old Jun 12, 2003 | 07:04 PM
Blitzkrieg's Avatar
I'm gonna hit the obvious here.
You say it was rebuilt 2 years ago but only has 25 hours on it.
How old is the gas that is in it right now?
Old Jun 12, 2003 | 08:12 PM
also, what are the conditions of your air filter, tranny oil, coolant? when were they checked/changed? what does your plug look like?
2-stroke fuel goes bad over time, so that could be the problem.
when you did the top end, what was the condition of the bottom end? did you replace the reeds?
another thing 've seen happen is the screws holding the stator & lighting coils unscrewed themselves & caused a similar condition on a friend's LT.
we need more info than 'scalded cat to ship on a stick' to help you out
Old Jun 13, 2003 | 12:21 AM
howler666's Avatar
the last time it was rebuilt, the entire motor was redone, bore out, bottom end rebuilt, and top end, o dont know about the reed tho. but i got it going 2 day, its not that it lack bottom end it just that the bottom end isnt snappy any more and wants to stall alot. i took my pipe off 2day to take a quick took at the piston and it look in really good shape, ever since i pressur washed it its been runing wierd, in my carb pluged?, and i think i got like 35-40 hours on it but the piston is fine. i need to get it fixed soon so i can sell it, i want to buy a banshee. and yes i know about 2-strokes, but this was my first bike and by the time i got enough knoledge to how to work on it there where soo many problems i just ran it out, witch i shouldnt have. by the way how do u rebuild a bottom end?
Old Jun 13, 2003 | 12:27 AM
howler666's Avatar
i havnt change the oil once, it has no manual so i dont how much oil to put in, but the coolant is fine, the top off my piston is really scratchy like sand paper and has an upper curve, i think my piston is F*cked
Old Jun 16, 2003 | 03:51 AM
Icehouse's Avatar
Working on 2 -strokes is so easy but its all trial and error . Check your compression ,new plug, jetting ,fuel mixture, new gas , clean air filter, idle screw,and so on . Doing these things should be routine maintenance anyway so half of them are probably already ok. Oh yeah and make sure all the wiring is connected properly, a losse conection can cripple your bike like you say.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
