zilla reed spacer
Old Sep 20, 2003 | 04:22 AM
85lt250r's Avatar
Default zilla reed spacer
what will a reed spacer do for me on an 87 zilla?
is it worht the price?
how will it effect performance?
Old Sep 20, 2003 | 10:03 AM
donzilla's Avatar
i put one on mine and it helped . it helps the air flow (smooth it out) . it took some of the snappy spots of the throttle and evened them out . (not so touchy) . i went with the pro design one .
Old Sep 20, 2003 | 10:45 AM
Halfliter's Avatar
I made a few different thickness ones and dynoed them. None worked. It seems that the 500 has too much crank case volume and reed spacers hurt that even more. Reed spacers seem to work on motors that the reeds block part of the boost port. Alot of Yamahas have that problem. Yamaha tends to run real tight cases which reed motors love.
By the way, I also tried a straight in intake boot and there was an increase but hardly noticable. Not enough to worry about trying to fit one in.
Just my findings.
Old Sep 23, 2003 | 02:29 PM
Duneaddict's Avatar
I'll agree w/ Halfliter, they are not needed on the 500...
Old Sep 23, 2003 | 03:34 PM
85lt250r's Avatar
good to know, i put one on the quad with no noticable diffrence, and in fact it only made the throttle cable take a sharp bend against the frame b moving the carb back. I was going to try to make a couple runs and then remove it quick and see if i could tell the diffrence, but it seems like now it will come off for good.
thanks.
hey, anybody wanna by a slightly used reed spacer for a zilla? [img]i/expressions/face-icon-small-smile.gif[/img]
QuadRiders
Oct 22, 2015 04:13 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
