230 cam chain timing
Old Jan 29, 2004 | 07:43 PM
tom18801's Avatar
Default 230 cam chain timing
i tore my motor to put in new valve seals and i dropped the chain down into the case and i now have it out and i dont know how to get the cam back in time with the can anyone help me get this retimed?
Old Jan 29, 2004 | 08:21 PM
LT250Rodney's Avatar
There should be a T shaped mark on the cam gear. It has to allign with the head so the T is upside down. Youl have a flat line paralell with the head and one sticking up 90 degrees to the head.
If i had the manual id scan you a pic... but its in my toolbox at work. Sorry!
Old Jan 29, 2004 | 09:04 PM
tom18801's Avatar
thanks man although does the piston have to be a top center or something like that?
Old Jan 29, 2004 | 09:40 PM
Vinson581's Avatar
look AT THE CAM, there is a D if you flip the Dcounter clockwise 90 degrees, the motor needs to be a TDC(top dead center) you kinda need 2 people to do this, i am a timing pro, done it about 20 times on my 230 lol, damn that sucks.
i can scan the page outta the factory manuel if you need.
v581
Old Jan 29, 2004 | 11:56 PM
Ooopsy, for the engine to be at TDC, there is a small plug right near your magneto cover, remove it and roll the engine over until a T comes into view clearly, thats TDC. Sorry I forgot about that. Then do the other step I told you to do.
Old Feb 2, 2004 | 08:21 AM
tom18801's Avatar
well what both if you guys said dosent apply because my cam dosent have a d or at on it it looks more like an e and this is an 86 230 quadsport and there is no plug to remove near the mag cover but the mag cover and flywheel are off anyway so its easy to find tdc do you have anymore ideas
Old Feb 2, 2004 | 05:50 PM
Exactly what model is your bike? There are a lot of different 230's. The method I explained applies to a LT230e. Chain drive, auto clutch. Anything else and I'll have to get my manual from work. Sorry to confuse you.
Old Feb 3, 2004 | 08:27 AM
tom18801's Avatar
this is chain drive manual clutch
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
