best replacement carb 04 eiger auto 4x4 ?
Old 02-03-2004 | 07:11 PM
steinster's Avatar
Default best replacement carb 04 eiger auto 4x4 ?
hi don here i have a 04 eiger auto 4x4 400 and i want to know if there is a better carb out there for this atv yet and if so online where can i go for the best price ? preformance ? easy to adjust too take care
Old 02-22-2004 | 08:56 PM
eigerbever's Avatar
Hey , off the subject, but what do you use to get the foward screws out on the float bowl?? My 1/4 in ratchet and phillips tip are too long to get in there. I figure I may just buy an offset screwdriver.
Old 02-22-2004 | 11:43 PM
eiger2's Avatar
Take the carb loose and twist er over.
Old 02-23-2004 | 06:01 PM
eigerbever's Avatar
Thanks , I kinda assumed that after taking a closer look. Keep ridin"""
Old 02-23-2004 | 07:06 PM
eigerbever's Avatar
When you loosen carb , do you loosen it from foward and aft clamp. or do you remove foward allen head bolts???
Old 02-24-2004 | 01:02 AM
eiger2's Avatar
Just loosen the clamps. If you pull the carb all the way out I think its easier to put back in if you put in the rear one first.
Old 02-24-2004 | 06:05 PM
eigerbever's Avatar
Thanks Brad , worked great. i installed inline filter. BTW Took fuel valve apart , found crap in there. Runs greats now!!!!
neilbedwell
11-10-2018 11:02 AM
Ty Speece
07-02-2015 04:59 PM
DOAinNY
06-11-2015 10:34 PM
generalpops
06-05-2015 08:23 PM
generalpops
06-03-2015 08:25 PM
Quick Reply: best replacement carb 04 eiger auto 4x4 ?
