1988 Quadracer 250 info please?
Old Apr 27, 2004 | 11:38 PM
Bivwak3's Avatar
Default 1988 Quadracer 250 info please?
I just bought an 88 quadracer last saturday, but it needs a new clutch. How hard would it be for me , who has some garage experience to replace the plates myself, and ofcourse with the Help of the manual.
Also the quad is completely stock , and i was wondering about how fast should this atv be once fixed, because I really have yet to get a feel of the power it is supposed to have? Thanks[img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 27, 2004 | 11:40 PM
Bivwak3's Avatar
Also I was wondering which mods would be best bang for the buck in my attempts to extract alot of power from this machine, Thanks.
Old Apr 28, 2004 | 12:05 AM
badchad's Avatar
Replacing your clutch plates should be no problem at all if you have any wrenching experiance, especially if you have a manual as stated. Just remember to soak your fiber plates overnight in oil before you replace them. I suggest replacing both steel and fiber plated and all springs as well if you have just purchased the quad. There's no telling if the previous owner has ever changed them!
You should be able to get 70+ MPH out of the quad with no problem depending on what is done to it. If the motor is stock, my first recomendation would be to get a pipe and silencer, a good air filter (either a dual stage foam or a K&N paper type), and a good reed cage and some reeds. That alone will help out a lot. After that, sky is the limit!
Good luck and have fun with the new toy.
Old Apr 28, 2004 | 07:23 PM
FMFrideLTs's Avatar
i have an 86. i have a FMF fatty pipe and silencer, FMF torque reeds, stock cylinder bore and barrnett racing clutch... man you could also play around with your front and rear sprockets, that will mess with you low end and top end speeds. you could also try different oils. i run H1R in mine at 40:1... it has been clocked close to 90 MPH... good luck man anything else just ask...
Old Apr 28, 2004 | 08:03 PM
needaR's Avatar
90 MPH???that seems kinda high with a just the mods mentioned and being an 86 5 speed.what gearing do you run?
Old Apr 28, 2004 | 08:48 PM
1987LT250's Avatar
wow 90 eh wif only a pipe and reeds hmmm mine does about 90 now that i added pipe and 38mm air stryker but only did 83 stock wif 14 tooth sprocket but took off slowwwwwwwwwwwwww and i got 6 gears lol what size tires u runnin on that thing 22s lmfao j/k
Old Apr 28, 2004 | 09:10 PM
needaR's Avatar
lol.i have 22's.spider surtracs.when these wear im gonna get 20's
Old Apr 28, 2004 | 09:19 PM
Bivwak3's Avatar
Thanks alot i will be taking all of your advice into account, thanks alot
Old Apr 28, 2004 | 10:26 PM
1987LT250's Avatar
by the way need i dropped ur powervalve cap at post office thank me when ya get it and its not broke found a good one now watch ill break mine lol
Valder
Nov 28, 2020 07:38 AM
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
